주요 콘텐츠로 건너뛰기
How to Clean a YardWork LH3185A Snow Blower Carburetor
필요한 것
  1. How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 1 단계, 이미지 3개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 1 단계, 이미지 3개 중 2개 How to Clean a YardWork LH3185A Snow Blower Carburetor, How to Clean a YardWork LH3185A Snow Blower Carburetor: 1 단계, 이미지 3개 중 3개
    • Block the gas from coming out of the fuel tank using a locking plier.
    • Alternatively, some snowblowers come with a shut-off valve to lock off the gas line.
  2. How to Clean a YardWork LH3185A Snow Blower Carburetor: 2 단계, 이미지 2개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 2 단계, 이미지 2개 중 2개
    • Remove the stop key by pulling outwards.
  3. How to Clean a YardWork LH3185A Snow Blower Carburetor: 3 단계, 이미지 1개 중 1개
    • Remove the choke key using a flat screwdriver.
  4. How to Clean a YardWork LH3185A Snow Blower Carburetor: 4 단계, 이미지 2개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 4 단계, 이미지 2개 중 2개
    • Remove the two support bolts from the outer shield using an 8 mm socket.
  5. How to Clean a YardWork LH3185A Snow Blower Carburetor: 5 단계, 이미지 1개 중 1개
    • Remove another two support bolts from the outer shield using a Phillips head screwdriver.
  6. How to Clean a YardWork LH3185A Snow Blower Carburetor: 6 단계, 이미지 1개 중 1개
    • Loosen the handlebar by turning the knob counterclockwise until there's enough room to safely remove the shield.
  7. How to Clean a YardWork LH3185A Snow Blower Carburetor: 7 단계, 이미지 2개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 7 단계, 이미지 2개 중 2개
    • Remove the inner switch using the 8mm socket.
  8. How to Clean a YardWork LH3185A Snow Blower Carburetor: 8 단계, 이미지 3개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 8 단계, 이미지 3개 중 2개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 8 단계, 이미지 3개 중 3개
    • Remove the bolt that holds the reservoir in place using a 13mm socket or spanner.
    • Gas can leak when removing the jet, so have a bucket or towel in place.
  9. How to Clean a YardWork LH3185A Snow Blower Carburetor: 9 단계, 이미지 1개 중 1개
    • Remove the reservoir by pulling downwards.
  10. How to Clean a YardWork LH3185A Snow Blower Carburetor: 10 단계, 이미지 2개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 10 단계, 이미지 2개 중 2개
    • Clean the jet nozzle (all three holes) using a pin or small wire.
  11. How to Clean a YardWork LH3185A Snow Blower Carburetor: 11 단계, 이미지 3개 중 1개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 11 단계, 이미지 3개 중 2개 How to Clean a YardWork LH3185A Snow Blower Carburetor: 11 단계, 이미지 3개 중 3개
    • Clean the inside of the reservoir, the rubber, and the jet using the carburetor cleaner.
    • When reassembling the reservoir, it is crucial to carefully position the rubber component. Improper alignment of the rubber, combined with excessive tightening of the bolt, can result in damaging the rubber seal.
결론
작성자
3다른 기여자 명과 함께
Demitri Roopnarine
회원 가입일: 05/28/23
293 평판
안내서 1개를 작성함
York University, Team A-7, Allen Summer 2023 York University, Team A-7, Allen Summer 2023 회원
YORK-ALLEN-SU23SAG7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 45
지난 30일: 242
전체 시간: 1,320
