필요한 것
Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
이 단계에 사용된 도구:Plastic Cards$2.99
Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
Please refer to the previous guide in order to reassemble your device.
다른 4명이 해당 안내서를 완성하였습니다.
