주요 콘텐츠로 건너뛰기
How to Clean and Apply Thermal Compound
필요한 것
  1. How to Clean and Apply Thermal Compound, How to Clean and Apply Thermal Compound: 1 단계, 이미지 1개 중 1개
    • Saturate a cotton swab with isopropyl alcohol, and remove the thermal compound from the thermal plates on your component using gentle circular motions.
    • As the cotton swab becomes saturated with thermal compound, discard and continue with a freshly dipped cotton swab. The compound plate is clean when the cotton swabs come away clean.
  2. How to Clean and Apply Thermal Compound: 2 단계, 이미지 2개 중 1개 How to Clean and Apply Thermal Compound: 2 단계, 이미지 2개 중 2개
    • Repeat the same cleaning process from the previous step on the matching thermal plates on the motherboard.
    • Avoid touching the thermal compound areas once they are clean. Dirt or oil on either surface can disrupt cooling performance and lead to overheating or thermal throttling.
  3. How to Clean and Apply Thermal Compound: 3 단계, 이미지 2개 중 1개 How to Clean and Apply Thermal Compound: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Apply a small amount of thermal compound, about the size of a grain of rice, on the corner of each the cleaned thermal plates on the motherboard.
    • Using a clean plastic card, carefully spread the thermal compound evenly over the surfaces of each thermal plate.
    • You need to clean the thermal plates on both the component and the motherboard, but you only need to apply thermal paste on the motherboard thermal plates.
    • Avoid applying too much or too little thermal compound, as it can impede crucial heat transfer. Once spread, the compound should be about as thick as a single sheet of paper.
  4. How to Clean and Apply Thermal Compound: 4 단계, 이미지 1개 중 1개
    • Gently re-seat your component, making sure that the thermal plates align correctly.
결론
Please refer to the previous guide in order to reassemble your device.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Reina Godeck
회원 가입일: 10/16/17
741 평판
안내서 5개를 작성함
UW Tacoma, Team S3-G5, Liner Fall 2017 UW Tacoma, Team S3-G5, Liner Fall 2017 회원
UWT-LINER-F17S3G5
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 28
전체 시간: 2,625
