주요 콘텐츠로 건너뛰기
How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar
필요한 것
  1. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 1 단계, 이미지 1/2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar, How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 1 단계, 이미지 2/2
    • Clear the workspace of any items or clutter that could damage the finish of the guitar.
    • Support the neck of the guitar with a stand or bag.
    • In this case, a neck stand was not available, so a toiletries bag with towels stuffed inside was used to support the neck of the guitar.
    • You are good to go as long as it is stable and supports the guitar's neck well.
  2. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 2 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 2 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 2 단계, 이미지 3/3
    • Using the string winder, unwind the strings.
    • It is okay to relieve all of the tension on the neck by unwinding all of the strings at once.
  3. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 3 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 3 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 3 단계, 이미지 3/3
    • Using the string winder, pull up the bridge pins.
    • Remove the old strings.
    • This allows complete access to clean and oil the frets and fretboard.
  4. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 4 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 4 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Use a scouring pad to clean and oil the fretboard, frets, and bridge with the Dunlop Lemon Oil.
    • Let the oil sit and seep into the wood for five minutes.
    • This is done so that the oil is absorbed into the wood of the fretboard and bridge, benefitting the longevity and life of the wood.
    • Once done, wipe off all of the excess oil with a microfiber cloth.
  5. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 5 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 5 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 5 단계, 이미지 3/3
    • It is important to use clean microfiber cloths for this step.
    • Use the Dunlop cleaner to clean the front, back, sides, and neck of the guitar.
    • Finish up with the Dunlop Carnauba wax to polish the front, back, sides, and neck of the guitar.
  6. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 6 단계, 이미지 1/2 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 6 단계, 이미지 2/2
    • Insert the new strings into the bridge holes.
    • Pop the bridge pins down into place.
    • Make sure to keep tension on the strings as the bridge pins are popped down into place.
  7. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 7 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 7 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 7 단계, 이미지 3/3
    • Cut the strings to size.
    • For the bass strings, measure one tuner head's length and trim it there.
    • For the treble strings, measure one and a half tuner head's length and trim it there.
    • When inserting the string into the tuning post, the string end should protrude approximately 1/8th of an inch from the tuner hole.
    • The bass side tuning pegs should be turned in a counter-clockwise direction to tune to pitch and the treble side tuning pegs should be turned in a clockwise direction to tune to pitch.
    • Make sure to remember that the wraps around the tuning post must go under the string to properly stay in tune and to avoid creating a kink, which could break the string.
    • Two to three wraps are perfect for the bass strings. The treble strings require approximately six wraps.
  8. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 8 단계, 이미지 1/1
    • Use a tuner to tune all of the strings to their proper notes.
    • The standard tuning for a six-string guitar is E A D G B E, which reads from the Low E (6th string) to the High E (1st string).
  9. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 9 단계, 이미지 1/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 9 단계, 이미지 2/3 How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 9 단계, 이미지 3/3
    • Stretch out each of the strings to help them intonate and stay in tune faster.
    • You will have to tune the guitar multiple times until the strings stay in tune when stretched.
    • Repeat this step until the guitar stays in tune.
  10. How to Clean and Restring an Epiphone EJ-200 Acoustic Guitar: 10 단계, 이미지 1/1
    • Enjoy your newly strung, cleaned, and maintained instrument.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Michael Dieguez
회원 가입일: 04/07/21
208 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G5, Harris Spring 2021 CSU Los Angeles, Team S1-G5, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 1,391
