주요 콘텐츠로 건너뛰기
How to Clean and Sharpen your Andis Hair Clippers
필요한 것
동영상 개요
  1. How to Clean and Sharpen your Andis Hair Clippers, How to Clean and Sharpen your Andis Hair Clippers: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to loosen the set screws by turning them left.
    • Remove the blade from your clipper.
  2. How to Clean and Sharpen your Andis Hair Clippers: 2 단계, 이미지 1개 중 1개
    • Take a fine hair brush and sweep it across the clipper base.
    • This will remove any hair debris.
  3. How to Clean and Sharpen your Andis Hair Clippers: 3 단계, 이미지 1개 중 1개
    • Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present.
    • The blade should soak a minimum of 5 minutes.
  4. How to Clean and Sharpen your Andis Hair Clippers: 4 단계, 이미지 1개 중 1개
    • Take a clean lint free towel and dry the blade.
    • While drying, rub the blade in all directions applying light pressure to remove residue and polish the blade.
  5. How to Clean and Sharpen your Andis Hair Clippers: 5 단계, 이미지 1개 중 1개
    • Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
  6. How to Clean and Sharpen your Andis Hair Clippers: 6 단계, 이미지 1개 중 1개
    • Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade.
    • This will clean your stone and remove any debris.
  7. How to Clean and Sharpen your Andis Hair Clippers: 7 단계, 이미지 1개 중 1개
    • Place your blades back into position and insert your set screws into the proper holes. Use a Phillips #0 screwdriver to secure the screws.
    • Be careful to line up your blades correctly.
  8. How to Clean and Sharpen your Andis Hair Clippers: 8 단계, 이미지 1개 중 1개
    • Apply oil to the base of your blades before your first use.
    • Blades should be oiled after every 3 or 4 uses.
  9. How to Clean and Sharpen your Andis Hair Clippers: 9 단계, 이미지 1개 중 1개
    • Your clippers are ready for use.
    • Plug them in to let them run for a few moments before your first use.
결론
Now that your clippers are clean and sharp, they're ready to tackle any haircut with ease. Remember to oil them regularly and repeat this cleaning process every few haircuts to maintain optimal performance. Enjoy using your freshly sharpened clippers!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony Pablo
회원 가입일: 03/18/24
337 평판
안내서 2개를 작성함
Anthony's Team Anthony's Team 회원
Community
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 69
전체 시간: 634
