주요 콘텐츠로 건너뛰기
How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel
필요한 것
  1. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel, How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the stickers that are hiding the screws.
    • The sticker may or may not stick back on the mouse after you complete the cleaning. You may want to use some clear tape to replace the stickers.
  2. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 2 단계, 이미지 1개 중 1개
    • Remove four screws using a Phillips #0 screwdriver.
  3. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 3 단계, 이미지 2개 중 1개 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 3 단계, 이미지 2개 중 2개
    • Use a spudger to pry along the center seam of the mouse.
    • Open the outer casing of the mouse.
  4. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 4 단계, 이미지 1개 중 1개
    • Remove the wires from the white crimp headers in order to separate the upper and lower housing units of the mouse.
    • Pull the wires as gently as possible to ensure that the wires will not break.
  5. How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 5 단계, 이미지 2개 중 1개 How to Clean the Anker 2.4G Wireless Mouse Scroll Wheel: 5 단계, 이미지 2개 중 2개
    • Take a cotton swab and lightly remove any dirt or debris around the pin connections of the scroll wheel.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Colin
회원 가입일: 02/10/14
406 평판
안내서 3개를 작성함
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 회원
CPSU-MANESS-W14S1G39
4 회원들
안내서 16개를 작성함
1가이드 댓글
You don’t tell how to put the stickers back because they won’t stick again…
p.pisu - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 30
전체 시간: 16,517
