주요 콘텐츠로 건너뛰기
How to Clean the Coffee Outlets on Your Jura Machine
AI 제작 동영상 안내서
이 안내서는 AI를 사용하여 제작한 YouTube 동영상입니다. 모든 저작권은 동영상 원작자에게 있습니다.
동영상 개요
  1. How to Clean the Coffee Outlets on Your Jura Machine, Locate the coffee outlets: 1 단계, 이미지 2개 중 1개 How to Clean the Coffee Outlets on Your Jura Machine, Locate the coffee outlets: 1 단계, 이미지 2개 중 2개
    • Identify the two outlets on your Jura machine, each containing a cross where the coffee is channeled down.
  2. How to Clean the Coffee Outlets on Your Jura Machine, Clear the outlets: 2 단계, 이미지 2개 중 1개 How to Clean the Coffee Outlets on Your Jura Machine, Clear the outlets: 2 단계, 이미지 2개 중 2개
    • Carefully clear any blockages at the cross within the outlets, avoiding the use of sharp or hard objects to prevent damage.
    • ipe cleaners and toothpicks are very suitable tools.
    • Ensure to proceed with care, understanding that the design allows for safe clearing without damaging internal components.
    • There is no risk of harming tubes or other internal parts during this process, when using appropriate methods.
  3. How to Clean the Coffee Outlets on Your Jura Machine: 3 단계, 이미지 2개 중 1개 How to Clean the Coffee Outlets on Your Jura Machine: 3 단계, 이미지 2개 중 2개
    • This method is not a permanent solution. If you've ever seen a heavily soiled outlet, you'll want to do a deep clean!
    • You have to remove the outlet to do this. See this guide for the Jura Z or Jura CEF, for example.
결론
Still having issues? Try some basic troubleshooting, or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
eCuration
회원 가입일: 05/19/17
450,149 평판
안내서 252개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 59
지난 30일: 203
전체 시간: 2,516
