주요 콘텐츠로 건너뛰기
How to Clean the Condenser Coils in your Whirlpool Refrigerator
필요한 것
  1. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Safety precautions: 1 단계, 이미지 1개 중 1개
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the rear panel.
    • Loosen the screw securing the water hose enough for the rear panel to freely move.
  3. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the rear panel: 3 단계, 이미지 3개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the rear panel: 3 단계, 이미지 3개 중 2개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Pull the rear panel off the chassis to remove it.
  4. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Open the doors: 4 단계, 이미지 3개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Open the doors: 4 단계, 이미지 3개 중 2개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Open the doors: 4 단계, 이미지 3개 중 3개
    • Depending on your repair, open one or both doors.
  5. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the front panel: 5 단계, 이미지 3개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the front panel: 5 단계, 이미지 3개 중 2개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Unfasten the front panel: 5 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the front panel.
  6. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the front panel: 6 단계, 이미지 3개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the front panel: 6 단계, 이미지 3개 중 2개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Remove the front panel: 6 단계, 이미지 3개 중 3개
    • Pull the front panel straight off the chassis and remove it.
    • You may have to slightly open the water filter door to remove the front panel completely.
  7. How to Clean the Condenser Coils in your Whirlpool Refrigerator, Vacuum the condenser coils: 7 단계, 이미지 2개 중 1개 How to Clean the Condenser Coils in your Whirlpool Refrigerator, Vacuum the condenser coils: 7 단계, 이미지 2개 중 2개
    • Vacuum any dust or debris clinging to the black condenser coils.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,945 평판
안내서 89개를 작성함
3가이드 댓글
Thanks for this, step 5 helped out a lot. I do have to say it is very frustrating trying to clean the coils on this model. The coils have that ‘V’ pattern all the way back which makes it really difficult to get a brush through. You almost need some type of access through the side to do this properly.
Kurt R - 답글
A genius idea to make sure the appliance has a shorter life, make sure there is no way to clean the coils. Whirlpool why dont you make a video showing how to clean the coils!!! LOL
Gary Bostow - 답글
Leaf blower works great!!!
colderp - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 91
지난 30일: 552
전체 시간: 9,966
