주요 콘텐츠로 건너뛰기
How to Clean the Dell MO56UC
필요한 것
  1. How to Clean the Dell MO56UC, Disassembly: 1 단계, 이미지 2개 중 1개 How to Clean the Dell MO56UC, Disassembly: 1 단계, 이미지 2개 중 2개
    • Unplug the USB cord to disconnect the mouse from the power
    • Use a Phillips 00 Screwdriver to unscrew one screw.
  2. How to Clean the Dell MO56UC, Complete mouse disassembly: 2 단계, 이미지 1개 중 1개
    • Take off the top of the mouse.
    • Use a microfiber cloth or a damp towel to remove any debris located inside of the highlighted areas.
  3. How to Clean the Dell MO56UC, Sensors: 3 단계, 이미지 1개 중 1개
    • Twist the ball counter-clockwise to remove it.
    • Clean the ball with a microfiber cloth.
  4. How to Clean the Dell MO56UC, Wipe gently with microfiber cloth: 4 단계, 이미지 1개 중 1개
    • Clean the vertical and horizontal ball sensors with a microfiber cloth.
  5. How to Clean the Dell MO56UC, Examining Wheel: 5 단계, 이미지 1개 중 1개
    • Examine the wheel for debris. The wheel can get dirty frequently which affects performance and may cause issues.
    • Remove any debris found and clean the wheel with a microfiber cloth.
  6. How to Clean the Dell MO56UC, Sensor Error: 6 단계, 이미지 1개 중 1개
    • The wheel clicker sensor is located under the wheel.
  7. How to Clean the Dell MO56UC, Wheel Clicker: 7 단계, 이미지 1개 중 1개
    • Remove the wheel to expose the sensor.
    • Remove any debris and wipe down the sensor with a microfiber cloth.
  8. How to Clean the Dell MO56UC, Plug it back in: 8 단계, 이미지 1개 중 1개
    • Insert the USB Cable back into your computer to supply with power.
    • Test functions of the mouse to insure proper cleaning and reassembly.
  9. How to Clean the Dell MO56UC, If there are still issues, Examine the cord and the USB leads in the male port: 9 단계, 이미지 1개 중 1개
    • Examine the cord for frays or any exposed wire that may cause a bad connection.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
Adrian Capparelli
회원 가입일: 10/23/14
180 평판
안내서 1개를 작성함
Montana Tech, Team 1-4, Shirk Fall 2014 Montana Tech, Team 1-4, Shirk Fall 2014 회원
MTUM-SHIRK-F14S1G4
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 21
지난 30일: 97
전체 시간: 4,856
