주요 콘텐츠로 건너뛰기
How to Clean the Fan on a Toshiba TDP-XP2
필요한 것
  1. How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: 1 단계, 이미지 1/2 How to Clean the Fan on a Toshiba TDP-XP2, How to Clean the Fan on a Toshiba TDP-XP2: 1 단계, 이미지 2/2
    • Remove the two screws from the bottom plate as shown.
  2. How to Clean the Fan on a Toshiba TDP-XP2: 2 단계, 이미지 1/1
    • Remove the two screws on the bulb housing.
  3. How to Clean the Fan on a Toshiba TDP-XP2: 3 단계, 이미지 1/1
    • Pull the tab up and pull the bulb out vertically. Some force will be required, but it will come out.
  4. How to Clean the Fan on a Toshiba TDP-XP2: 4 단계, 이미지 1/1
    • Using a can of compressed air, blow on the fan until all dust is gone.
    • Oil can be added in with a dropper on the bearing if needed.
결론
Bryan Underwood
회원 가입일: 04/02/18
697 평판
안내서 5개 작성하였습니다
University of Memphis, Team S1-G3, Kim Spring 2018 University of Memphis, Team S1-G3, Kim Spring 2018 회원
UM-KIM-S18S1G3
3 회원들
안내서 5개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 355
