주요 콘텐츠로 건너뛰기
How to Clean the InFocus X2 Lamp Housing Screens
필요한 것
  1. How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 1 단계, 이미지 3개 중 1개 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 1 단계, 이미지 3개 중 2개 How to Clean the InFocus X2 Lamp Housing Screens, Open the Lamp Door: 1 단계, 이미지 3개 중 3개
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 2 단계, 이미지 3개 중 1개 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 2 단계, 이미지 3개 중 2개 How to Clean the InFocus X2 Lamp Housing Screens, Disconnect the Lamp: 2 단계, 이미지 3개 중 3개
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 3 단계, 이미지 3개 중 1개 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 3 단계, 이미지 3개 중 2개 How to Clean the InFocus X2 Lamp Housing Screens, Unscrew the Lamp from the Projector: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. How to Clean the InFocus X2 Lamp Housing Screens, Remove the Old Lamp: 4 단계, 이미지 1개 중 1개
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. How to Clean the InFocus X2 Lamp Housing Screens, Insert the New Lamp: 5 단계, 이미지 1개 중 1개
    • Insert the replacement lamp into the projector.
  6. How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: 6 단계, 이미지 2개 중 1개 How to Clean the InFocus X2 Lamp Housing Screens, Cleaning the Dirty Screens: 6 단계, 이미지 2개 중 2개
    • Use a vacuum cleaner to gently suck up the dust on the front and the back Lamp Housing screens.
결론
첨부 문서
작성자
1다른 기여자 명과 함께
Paulina Duarte
회원 가입일: 09/19/13
553 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S1G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 245
