주요 콘텐츠로 건너뛰기
How to Clean the Keurig K75 Platinum Brewing System Needle
필요한 것
  1. How to Clean the Keurig K75 Platinum Brewing System Needle, How to Clean the Keurig K75 Platinum Brewing System Needle: 1 단계, 이미지 1/1
    • Before needle repair, make sure the brewer is disconnected from any power outlet.
    • Lift the handle to open the top of the brewer.
    • There are two sharp needles that puncture the K-Cup pack. One is above the K-Cup holder and the other is in the bottom of the holder. Be careful when cleaning the top needle.
  2. How to Clean the Keurig K75 Platinum Brewing System Needle: 2 단계, 이미지 1/1
    • Bend a paperclip to create a vertical metal piece. This is used to clean the top needle.
  3. How to Clean the Keurig K75 Platinum Brewing System Needle: 3 단계, 이미지 1/1
    • Insert a paper clip into the exit needle to loosen the debris and push it out.
    • Repeat this action until the debris is cleared from the top needle.
    • All external pieces of the brewer are dishwasher safe.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexander Vo
회원 가입일: 01/11/13
94 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-2, Maness Winter 2013 Cal Poly, Team 20-2, Maness Winter 2013 회원
CPSU-MANESS-W13S20G2
4 회원들
안내서 6개 작성하였습니다
댓글 9개
must be something else on mine. i have cleaned out with paper clip 3 times and still no water comes out.
jjthdj - 답글
try descaling it
marymckercher -
Worked great for mine just now. I picked up a used B20 Platinum at a Garage Sale yesterday for only $10 super easy to clean needle & now it works great!! Thanks OP!!
ronald944 - 답글
My husband keeps wanting to buy me something new every time the old one doesn't work, well I am old fashioned and will do anything I can to save money. Thank goodness this worked than you so much.
Wendy Clark - 답글
How about the needle at the bottom of the holder?
tahoejb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 35
전체 시간: 21,968
