주요 콘텐츠로 건너뛰기
How to Clean the Rollers on an HP Deskjet 2624
필요한 것
    • Perform an automated self-clean by holding down the power button.
    • While the power button is held, press the button with the large red 'X' three times then press the button with the yellow, blue, and pink rim eight times.
    • Release the power button. A single sheet of paper should be fed through the printer.
    • Wait until the paper is completely through the printer before removing it.
  1. How to Clean the Rollers on an HP Deskjet 2624: 2 단계, 이미지 1/1
    • Once the automated is complete, attempt to print again.
    • If the paper jam persists, the rollers must be manually cleaned.
    • Begin by turning off and unplugging the printer.
  2. How to Clean the Rollers on an HP Deskjet 2624: 3 단계, 이미지 1/2 How to Clean the Rollers on an HP Deskjet 2624: 3 단계, 이미지 2/2
    • To access the rollers, remove all the paper in the feeding tray.
    • Lift the clear plastic flap on the top of the printer and look down the feeding section.
  3. How to Clean the Rollers on an HP Deskjet 2624: 4 단계, 이미지 1/2 How to Clean the Rollers on an HP Deskjet 2624: 4 단계, 이미지 2/2
    • Take a lightly dampened cotton swab and apply it to the grey segments of the rollers.
    • Rotate the rollers to completely clean the grey segments
결론
Wait approximately 10 minutes for the rollers to dry completely.
다른 2명이 해당 안내서를 완성하였습니다.
Ryan Doyle
회원 가입일: 01/16/20
578 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 24
30일 전: 98
전체 시간: 2,065
