주요 콘텐츠로 건너뛰기
How to Clear a Clog in a Keurig K-Mini
필요한 것
  1. How to Clear a Clog in a Keurig K-Mini, How to Clear a Clog in a Keurig K-Mini: 1 단계, 이미지 1/2 How to Clear a Clog in a Keurig K-Mini, How to Clear a Clog in a Keurig K-Mini: 1 단계, 이미지 2/2
    • Unplug the Keurig from the power source.
    • Lift the handle and locate the pod holder.
  2. How to Clear a Clog in a Keurig K-Mini: 2 단계, 이미지 1/3 How to Clear a Clog in a Keurig K-Mini: 2 단계, 이미지 2/3 How to Clear a Clog in a Keurig K-Mini: 2 단계, 이미지 3/3
    • Remove the pod holder from the Keurig.
  3. How to Clear a Clog in a Keurig K-Mini: 3 단계, 이미지 1/2 How to Clear a Clog in a Keurig K-Mini: 3 단계, 이미지 2/2
    • Separate the two pieces of the pod holder.
    • Run the pieces under hot water to loosen any potential debris.
    • After rinsing, pat dry.
  4. How to Clear a Clog in a Keurig K-Mini: 4 단계, 이미지 1/3 How to Clear a Clog in a Keurig K-Mini: 4 단계, 이미지 2/3 How to Clear a Clog in a Keurig K-Mini: 4 단계, 이미지 3/3
    • Using a sharp tool, such as a toothpick, thumbtack, or needle, wiggle the tool around the exit needle.
    • Any debris that is stuck should come loose.
  5. How to Clear a Clog in a Keurig K-Mini: 5 단계, 이미지 1/3 How to Clear a Clog in a Keurig K-Mini: 5 단계, 이미지 2/3 How to Clear a Clog in a Keurig K-Mini: 5 단계, 이미지 3/3
    • Use caution when searching for the entrance needle on the underside of the brewer head.
    • Carefully use the sharp tool to push into the hollow needle.
    • Wiggle the tool around as needed until the blockage is removed.
    • Reassemble the Keurig and plug into the power source. Turn on the machine.
결론
Run the machine on the largest cup setting while leaving the pod holder empty. This will show if the blockage has been removed, or if the process will need to be repeated to loosen the blockage. Potential blockages may also be removed during this cycle.
다른 4명이 해당 안내서를 완성하였습니다.
Maureen Isbell
회원 가입일: 01/13/21
213 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 122
전체 시간: 4,843
