주요 콘텐츠로 건너뛰기
How to Clear a blocked, or clogged sink
  1. How to Clear a blocked, or clogged sink, How to Clear a blocked, or clogged sink: 1 단계, 이미지 1/1
    • When you first go to clear your sink, you should check how the pipes are connected.
  2. How to Clear a blocked, or clogged sink: 2 단계, 이미지 1/1
    • If your piping looks like the photo, you won't need tools to make this fix.
    • You can easily remove these pipes by twisting them off at the brackets.
  3. How to Clear a blocked, or clogged sink: 3 단계, 이미지 1/2 How to Clear a blocked, or clogged sink: 3 단계, 이미지 2/2
    • Twist the higher bracket until it comes undone.
  4. How to Clear a blocked, or clogged sink: 4 단계, 이미지 1/1
    • Twist the lower bracket until it also comes undone.
    • Water and other liquids will pour out of the brackets so hold the pipe tightly to avoid making a mess.
  5. How to Clear a blocked, or clogged sink: 5 단계, 이미지 1/1
    • Gently remove the pipe and find somewhere to dump out the contents that caused it to be clogged.
    • The pipe will be full of water and whatever is stuck inside. Any large obstructions or other blockages may fall out.
  6. How to Clear a blocked, or clogged sink: 6 단계, 이미지 1/1
    • Clear out the gunk, obstructions, and any other objects in the pipe so that your sink drains properly.
  7. How to Clear a blocked, or clogged sink: 7 단계, 이미지 1/1
    • Repeat the steps in reverse to put it back together again.
    • The blockage should now be removed and the sink should be draining properly.
결론
Your sink should now be free of obstructions or clogs in the pipes.
다른 4명이 해당 안내서를 완성하였습니다.
Elijah Santiago
회원 가입일: 09/18/15
196 평판
안내서 1개 작성함
Pasco Hernando, Team 5-1, Prince Fall 2015 Pasco Hernando, Team 5-1, Prince Fall 2015 회원
PHSC-PRINCE-F15S5G1
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Smalll repairs can be done on a diy basis, but if drain clogging a regular problem the best solution would be to turn to professional pipe cleaning and restoration. i.e. pipe rehabilitation.
Kanserwis Sp. z o.o - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 22
전체 시간: 1,773
