주요 콘텐츠로 건너뛰기
How to Connect LED Strip Lights
필요한 것
  1. How to Connect LED Strip Lights, How to Connect LED Strip Lights: 1 단계, 이미지 2개 중 1개 How to Connect LED Strip Lights, How to Connect LED Strip Lights: 1 단계, 이미지 2개 중 2개
    • Attach one strand of lights using the pre applied glue or a hot glue gun where you desire.
    • Make sure you leave a little slack at the end of the strand to connect to the second strand of lights.
  2. How to Connect LED Strip Lights: 2 단계, 이미지 2개 중 1개 How to Connect LED Strip Lights: 2 단계, 이미지 2개 중 2개
    • Find the other side labeled RGB with prongs and/or wires and repeat the process from Step 1.
    • Leave slack on the end to reach the other strand.
  3. How to Connect LED Strip Lights: 3 단계, 이미지 1개 중 1개
    • Once you determine which side you have ended with (either prong side or plate side), you will then determine which set of RGB labeled plates you will connect to.
  4. How to Connect LED Strip Lights: 4 단계, 이미지 1개 중 1개
    • Using the prong side make sure both sides line up “RGB” to “RGB” on both sides.
    • Place each prong so it coordinates with the correct opposite plate.
    • Push towards the wall into the plate using the prongs and make a firm connection.
  5. How to Connect LED Strip Lights: 5 단계, 이미지 1개 중 1개
    • Using tape or hot glue firmly secure the center of the connection to the wall or desired area making sure there is little movement in the wires.
    • Try and avoid gluing the metal plates. You may cut off connection from your prongs if not careful.
  6. How to Connect LED Strip Lights: 6 단계, 이미지 3개 중 1개 How to Connect LED Strip Lights: 6 단계, 이미지 3개 중 2개 How to Connect LED Strip Lights: 6 단계, 이미지 3개 중 3개
    • Turn on the light strip to make sure all the lights come on. Test to see if the colors change to make sure they all look correct and match each other.
    • If they do not work correctly restart from step two.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Maxwell Moore
회원 가입일: 09/28/21
217 평판
안내서 1개를 작성함
1가이드 댓글
I broke the strip how do I fix it?
Melody James - 답글
댓글 쓰기
조회 통계:
지난 24시간: 26
지난 7일: 168
지난 30일: 679
전체 시간: 55,438
