주요 콘텐츠로 건너뛰기
How to Create a Custom Cotton Swab
필요한 것
  1. How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Find a tool: 1 단계, 이미지 3개 중 3개
    • Find a small object with a pointed end, such as:
    • A toothpick
    • A spudger
    • The end of a flossing pick
    • Avoid metal objects, like paperclips, or anything brittle that might break off in the charging port.
  2. How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Separate the cotton: 2 단계, 이미지 3개 중 3개
    • Pull off a small part of a cotton ball.
    • You only need a small amount of cotton—enough to create a thin layer around your tool.
  3. How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Apply the cotton: 3 단계, 이미지 3개 중 3개
    • Wrap the cotton around the tip of your tool.
    • Roll the cotton between your fingers to compress it into a thin layer.
  4. How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 1개 How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 2개 How to Create a Custom Cotton Swab, Remove any excess cotton: 4 단계, 이미지 3개 중 3개
    • Test your cotton swab on your device to see if it fits.
    • If your swab doesn't fit, remove any excess cotton and reroll your cotton so it's compressed and tight along the tip of your tool.
    • If the swab still doesn't fit, you may need to find a different tool altogether.
    • Your custom cotton swab is ready! Return to where you left off in your guide.
결론
For other general electronics skills guides, click here.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
213,232 평판
안내서 1,040개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
1가이드 댓글
My samsung a14 won't charge
Tebogo madibana - 답글
댓글 쓰기
조회 통계:
지난 24시간: 28
지난 7일: 188
지난 30일: 878
전체 시간: 12,902
