주요 콘텐츠로 건너뛰기
How to Create a USB boot drive for Windows 10
필요한 것
  1. How to Create a USB boot drive for Windows 10, Get the Media Creation Tool: 1 단계, 이미지 1/1
  2. How to Create a USB boot drive for Windows 10, Allow in UAC: 2 단계, 이미지 1/1
    • If you have UAC enabled click "Yes"
  3. How to Create a USB boot drive for Windows 10, Accept Ts & Cs: 3 단계, 이미지 1/2 How to Create a USB boot drive for Windows 10, Accept Ts & Cs: 3 단계, 이미지 2/2
    • Click "Accept"
    • Option: Actually read T&Cs
  4. How to Create a USB boot drive for Windows 10, Create installation media: 4 단계, 이미지 1/1
    • Select "Create installation media (USB flash drive, DVD or ISO file) for another PC"
    • Click "Next"
  5. How to Create a USB boot drive for Windows 10: 5 단계, 이미지 1/1
    • If you are creating a USB for another computer take care to get these settings correct for the computer it will be used on. Language is not so important as it can be changed later.
    • If you are creating a back up for the computer you are running the tool on, selecting the check box "Use the recommended options for this PC" will select the settings automatically.
  6. How to Create a USB boot drive for Windows 10: 6 단계, 이미지 1/1
    • Select "USB flash drive"
    • Click "Next"
    • By selecting "ISO file" you can create a disk image that can be burned to a CD or USB at a later date.
  7. How to Create a USB boot drive for Windows 10: 7 단계, 이미지 1/1
    • Now select the USB drive you wish to put the tool on.
    • If your drive does not appear here, make sure it is correctly inserted and detected by Windows.
  8. How to Create a USB boot drive for Windows 10, Download and verify: 8 단계, 이미지 1/3 How to Create a USB boot drive for Windows 10, Download and verify: 8 단계, 이미지 2/3 How to Create a USB boot drive for Windows 10, Download and verify: 8 단계, 이미지 3/3
    • Now windows will download and verify the installation files.
  9. How to Create a USB boot drive for Windows 10, Writing to disk: 9 단계, 이미지 1/2 How to Create a USB boot drive for Windows 10, Writing to disk: 9 단계, 이미지 2/2
    • Now windows will write the installation files to your drive.
  10. How to Create a USB boot drive for Windows 10, Final steps: 10 단계, 이미지 1/2 How to Create a USB boot drive for Windows 10, Final steps: 10 단계, 이미지 2/2
    • Once it's finished writing to the disk click "Next"
    • And after a short wait you're done!
결론
다른 82명이 해당 안내서를 완성하였습니다.
Conor Bailey
회원 가입일: 04/27/16
7,968 평판
안내서 2개 작성하였습니다
Tech Haus Tech Haus 회원
Business
1 회원
안내서 12개 작성하였습니다
댓글 23개
Mr. Bailey. How is this Boot drive different from the Recovery drive that I create directly from my PC? Thanks.
John Norton - 답글
They do the same thing essentially, they allow you to boot and recover your windows installation. However there is a one difference and that's that, I believe, the recovery drive tool only gives you the option to create a disk for the computer you are using. It's exactly like the recovery partition that some computers and laptops have.
My guide is quite generic in that you could create the disk for any Windows 10 installation.
Thanks for the question.
Conor Bailey -
From my practice, UUByte ISO Editor can also create disks for any Windows 10 installation (including Windows 7, Windows 8 and Mac).
And compared with the method shared by Mr. Bailey above, UUByte ISO Editor saves time for users because it only takes 3 steps to create a Windows 10 bootable USB on my PC. It has no difficulty for those new users.
KKEmily -
I recommend you add something about how to boot from the USB drive, especially on a machine that has UEFI SecureBoot enabled.
Bill Meacham - 답글
I agree that that part of the process is important, however there are so many variables to uefi that writing a coherent guide for that would be difficult. Not to mention that screen shotting those steps a more difficult (although obviously not impossible).
But thank you for the feed back, I'll consider it in the future.
Conor Bailey -
댓글 쓰기
조회 통계:
24 시간 전: 86
7일 전: 615
30일 전: 2,731
전체 시간: 358,033
