주요 콘텐츠로 건너뛰기
How to Decrease the Bicep of a Sleeve
필요한 것
  1. How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 1 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 1 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: 1 단계, 이미지 3개 중 3개
    • Flip your shirt inside out.
    • The raw edges should be on the outside.
  2. How to Decrease the Bicep of a Sleeve: 2 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve: 2 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve: 2 단계, 이미지 3개 중 3개
    • Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
    • Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
  3. How to Decrease the Bicep of a Sleeve: 3 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve: 3 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve: 3 단계, 이미지 3개 중 3개
    • Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
    • It should align with the sleeve at the cuff.
    • Draw another line from the marking, extending down to align with the side of the body of the shirt.
  4. How to Decrease the Bicep of a Sleeve: 4 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve: 4 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve: 4 단계, 이미지 3개 중 3개
    • Use straight pins to pin the sleeve across the lines you drew.
    • Push the pin through the top and push it back through the bottom of the sleeve.
    • Place a pin every inch across the lines.
  5. How to Decrease the Bicep of a Sleeve: 5 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve: 5 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve: 5 단계, 이미지 3개 중 3개
    • Using a sewing machine, sew across the pinned lines with a straight stitch.
    • Be sure to backstitch at the start and end of your stitch.
  6. How to Decrease the Bicep of a Sleeve: 6 단계, 이미지 3개 중 1개 How to Decrease the Bicep of a Sleeve: 6 단계, 이미지 3개 중 2개 How to Decrease the Bicep of a Sleeve: 6 단계, 이미지 3개 중 3개
    • Use scissors to cut off the excess fabric.
    • Leave a seam allowance of 6.4 mm.
  7. How to Decrease the Bicep of a Sleeve: 7 단계, 이미지 1개 중 1개
    • Measure again to see if you reached your desired width.
결론
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Elliot T
회원 가입일: 09/27/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 26
전체 시간: 395
