주요 콘텐츠로 건너뛰기
How to Descale a Nespresso Vertuo
필요한 것
  1. How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 1 단계, 이미지 3개 중 1개 How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 1 단계, 이미지 3개 중 2개 How to Descale a Nespresso Vertuo, How to Descale a Nespresso Vertuo: 1 단계, 이미지 3개 중 3개
    • Lift the machine head to ensure there are no capsules present inside.
    • Empty the capsule container by removing it from the machine and disposing of any used capsules.
  2. How to Descale a Nespresso Vertuo: 2 단계, 이미지 3개 중 1개 How to Descale a Nespresso Vertuo: 2 단계, 이미지 3개 중 2개 How to Descale a Nespresso Vertuo: 2 단계, 이미지 3개 중 3개
    • Fill the water tank halfway with fresh water.
    • Add 1 packet of the Nespresso descaling solution to the water tank.
    • Do not swallow or ingest the Nespresso descaling solution.
    • The Nespresso descaling solution may cause irritation to skin and/or eyes.
  3. How to Descale a Nespresso Vertuo: 3 단계, 이미지 2개 중 1개 How to Descale a Nespresso Vertuo: 3 단계, 이미지 2개 중 2개
    • To place the machine in descaling mode, begin with the lever in the unlocked position, parallel to the spout.
    • Press the button once and release it, then wait for the indicator light to turn on.
  4. How to Descale a Nespresso Vertuo: 4 단계, 이미지 1개 중 1개
    • Press and hold the button until the indicator light turns off, and then begins blinking.
    • It may take approximately 7 seconds before the light begins to blink.
  5. How to Descale a Nespresso Vertuo: 5 단계, 이미지 3개 중 1개 How to Descale a Nespresso Vertuo: 5 단계, 이미지 3개 중 2개 How to Descale a Nespresso Vertuo: 5 단계, 이미지 3개 중 3개
    • Rotate the lever to the left to secure it in the locked position.
    • Then return the lever back to the center to release the lock.
  6. How to Descale a Nespresso Vertuo: 6 단계, 이미지 1개 중 1개
    • Press and hold the button until the indicator light turns off and then begins blinking again.
    • Steps 5 and 6 must be completed within 45 seconds of each other.
  7. How to Descale a Nespresso Vertuo: 7 단계, 이미지 2개 중 1개 How to Descale a Nespresso Vertuo: 7 단계, 이미지 2개 중 2개
    • While the indicator light is blinking, rotate the lever to the left to place it in the locked position.
  8. How to Descale a Nespresso Vertuo: 8 단계, 이미지 3개 중 1개 How to Descale a Nespresso Vertuo: 8 단계, 이미지 3개 중 2개 How to Descale a Nespresso Vertuo: 8 단계, 이미지 3개 중 3개
    • Place a large container (20oz+) underneath the spout.
    • Press and release the button once to begin dispensing the descaling solution.
    • The machine will intermittently dispense the solution. Once the cycle has finished running, the machine will be silent.
    • Discard the solution.
  9. How to Descale a Nespresso Vertuo: 9 단계, 이미지 2개 중 1개 How to Descale a Nespresso Vertuo: 9 단계, 이미지 2개 중 2개
    • Rinse out the water tank.
    • Refill the water tank until it's about two-thirds full of fresh water and place it back onto the machine.
    • Place the large container back under the spout.
  10. How to Descale a Nespresso Vertuo: 10 단계, 이미지 1개 중 1개
    • Press and release the button one time to begin the rinsing process.
  11. How to Descale a Nespresso Vertuo: 11 단계, 이미지 1개 중 1개
    • Once the machine is silent and the water tank is empty, discard the water from the large container.
  12. How to Descale a Nespresso Vertuo: 12 단계, 이미지 1개 중 1개
    • To reset the machine for regular use, press and hold the button until the indicator light stops blinking.
  13. How to Descale a Nespresso Vertuo: 13 단계, 이미지 1개 중 1개
    • Wipe the machine down.
    • Let the machine rest for 10 minutes.
    • The machine is now ready for use.
결론
By regularly descaling your Nespresso Vertuo machine, you are preserving its functionality and contributing to environmental sustainability. Keeping your machine in good working condition helps reduce the likelihood of it ending up in a landfill prematurely, minimizing the environmental impact of electronic waste.
To ensure optimal performance and longevity, Nespresso recommends descaling your machine every 3 months or 300 pods, whichever comes first.
Thank you for taking the time to follow this guide and for your commitment to maintaining your Nespresso machine. Here's to many more cups of great-tasting coffee!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Rachel Davis
회원 가입일: 02/19/24
235 평판
안내서 1개를 작성함
CSU Sacramento, Team 1-10, Laflen Spring 2024 CSU Sacramento, Team 1-10, Laflen Spring 2024 회원
CSUSAC-LAFLEN-S24S1G10
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 54
지난 30일: 181
전체 시간: 2,969
