주요 콘텐츠로 건너뛰기
How to Descale a Nespresso VertuoPlus
필요한 것
  1. How to Descale a Nespresso VertuoPlus, How to Descale a Nespresso VertuoPlus: 1 단계, 이미지 1개 중 1개
    • Turn the machine on by pressing the button with a coffee mug logo.
  2. How to Descale a Nespresso VertuoPlus: 2 단계, 이미지 3개 중 1개 How to Descale a Nespresso VertuoPlus: 2 단계, 이미지 3개 중 2개 How to Descale a Nespresso VertuoPlus: 2 단계, 이미지 3개 중 3개
    • Lift the lever upwards to remove any used capsules from the machine.
    • Empty the capsule container that is located at the back of the machine.
  3. How to Descale a Nespresso VertuoPlus: 3 단계, 이미지 1개 중 1개
    • Turn the machine off by pushing the same lever down.
  4. How to Descale a Nespresso VertuoPlus: 4 단계, 이미지 1개 중 1개
    • Fill the water tank with one unit of the Nespresso descaling liquid and add three cups of water to the solution.
  5. How to Descale a Nespresso VertuoPlus: 5 단계, 이미지 1개 중 1개
    • To access the descaling mode on the machine, push both the button and lever down for three seconds.
    • You will see an orange light, indicating that you have reached the "Special Functions" menu.
  6. How to Descale a Nespresso VertuoPlus: 6 단계, 이미지 1개 중 1개
    • To access the descaling mode, press the lever down one time.
  7. How to Descale a Nespresso VertuoPlus: 7 단계, 이미지 1개 중 1개
    • To start descaling, push the button.
    • An orange light will start to blink indicating the descaling function.
    • The machine will stop automatically when completed.
  8. How to Descale a Nespresso VertuoPlus: 8 단계, 이미지 1개 중 1개
    • Empty the descaling liquid from the water tank.
    • Rinse and clean the tank thoroughly.
  9. How to Descale a Nespresso VertuoPlus: 9 단계, 이미지 1개 중 1개
    • Fill the water tank with fresh water and place it back into the machine.
  10. How to Descale a Nespresso VertuoPlus: 10 단계, 이미지 1개 중 1개
    • Push the button to rinse the machine.
  11. How to Descale a Nespresso VertuoPlus: 11 단계, 이미지 1개 중 1개
    • To exit descaling mode, press both the button and lever at the same time for three seconds.
  12. How to Descale a Nespresso VertuoPlus: 12 단계, 이미지 1개 중 1개
    • A green light will show, indicating the descaling has been completed successfully.
결승점
다른 45명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Olivia peet
회원 가입일: 02/15/21
1,285 평판
안내서 1개를 작성함
Texas Tech, Team S3-G18, Cowan Spring 2021 Texas Tech, Team S3-G18, Cowan Spring 2021 회원
TTU-COWAN-S21S3G18
1 회원
안내서 7개를 작성함
12가이드 댓글
When I hit the button to begin the descaling process, the orange light flashes for a few seconds then I get a red ring and the machine stops
James Spavelko - 답글
I usually require six envelopes to descale (six times). We have very hard water where we live. Keep repeating process. Once machine has descaled enough, it will go back to green. Persistence wins.
Laura Retana -
perchè pur funzionante si accende la spia circolare di colore per metà rossa e metà verde?
Attilio Carioti - 답글
Devi fare la decalcificazione ti da ancora la possibilità di usarla ma per un breve periodo
Luca Levra -
Perché dopo aver fatto la decalcificazione compare ancora la spia metà rossa e metà verde?
maria.padovano1 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 53
지난 7일: 555
지난 30일: 1,866
전체 시간: 219,581
