주요 콘텐츠로 건너뛰기
How to Disassemble an OXO Container Lid for Cleaning
필요한 것
  1. How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: 1 단계, 이미지 1/2 How to Disassemble an OXO Container Lid for Cleaning, How to Disassemble an OXO Container Lid for Cleaning: 1 단계, 이미지 2/2
    • Twist the bottom piece off by following the directions displayed on the lid.
    • Once inside, remove the outer layer seal from the lid by pulling it straight up.
  2. How to Disassemble an OXO Container Lid for Cleaning: 2 단계, 이미지 1/3 How to Disassemble an OXO Container Lid for Cleaning: 2 단계, 이미지 2/3 How to Disassemble an OXO Container Lid for Cleaning: 2 단계, 이미지 3/3
    • Flip the lid so the button faces up. Then remove the button from the base of the lid.
    • This requires more added force.
    • Separate the interior prongs.
  3. How to Disassemble an OXO Container Lid for Cleaning: 3 단계, 이미지 1/2 How to Disassemble an OXO Container Lid for Cleaning: 3 단계, 이미지 2/2
    • After separating the prongs, the spring and the circular spring cap will separate from the square frame with little force.
    • With some force, remove the two prongs from the base of the lid by snapping them out of the bracket. Be careful not to break the bracket's small prongs.
    • The disassembled parts can now be cleaned with warm, soapy water.
  4. How to Disassemble an OXO Container Lid for Cleaning: 4 단계, 이미지 1/2 How to Disassemble an OXO Container Lid for Cleaning: 4 단계, 이미지 2/2
    • To reassemble the lid, start by connecting the outer layer piece with the base piece. Grooves in the parts will only allow them to be connected in the correct way.
    • Place the spring in the center of the lid within the circular outline.
  5. How to Disassemble an OXO Container Lid for Cleaning: 5 단계, 이미지 1/1
    • Take the small interior circle and place it on top of the spring.
    • Use force to push this piece down. Make sure the slots align.
    • This piece will not stay in place on its own. Flip the lid over and keep it on a flat surface to prevent the spring from releasing.
  6. How to Disassemble an OXO Container Lid for Cleaning: 6 단계, 이미지 1/2 How to Disassemble an OXO Container Lid for Cleaning: 6 단계, 이미지 2/2
    • Reattach the two prongs to the lid.
    • Intertwine the two prongs together.
    • The spring should now be firmly held in place.
  7. How to Disassemble an OXO Container Lid for Cleaning: 7 단계, 이미지 1/2 How to Disassemble an OXO Container Lid for Cleaning: 7 단계, 이미지 2/2
    • Twist the bottom piece back on the lid.
    • Reattach the button to the center of the lid.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Lorna Lauro
회원 가입일: 04/20/22
187 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-77, Harris Spring 2022 CSU Los Angeles, Team 7-77, Harris Spring 2022 회원
CSULA-HARRIS-S22S7G77
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Excellent guide, a set I got came with the metal pins of the prongs unseated from their holes, causing the lid to operate incorrectly. I was able to re-seat them and get the lid working with the help of this.
Stefan Rust - 답글
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 66
30일 전: 310
전체 시간: 12,353
