소개
Follow this guide to disconnect the battery in an iPad with a playing card.
If you're having trouble fitting a battery blocker underneath the battery connector on an iPad's logic board, you can try using a playing card to disconnect the battery instead. This procedure requires cutting a playing card to size.
필요한 것
Line up the left edge of a playing card with the left edge of the battery connector.
Use a pen to mark both sides of the screw hole and the end of the battery connector as shown.
Line up the top edge of the card with the top edge of the screw hole.
Use a pen to mark the bottom edge of the battery connector.
Use a pair of scissors to cut out the playing card battery blocker as shown.
Insert the battery blocker at a 35 degree angle to disconnect the battery.
Leave the battery blocker in place as you work.
다른 9명이 해당 안내서를 완성하였습니다.
