주요 콘텐츠로 건너뛰기
How to Dry Wet Canon PowerShot SD850 IS Camera Components
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Battery: 1 단계, 이미지 1/1
    • Identify the battery port on the underside of the camera.
  2. How to Dry Wet Canon PowerShot SD850 IS Camera Components: 2 단계, 이미지 1/2 How to Dry Wet Canon PowerShot SD850 IS Camera Components: 2 단계, 이미지 2/2
    • Using your thumb, slide the port to the right and release.
  3. How to Dry Wet Canon PowerShot SD850 IS Camera Components: 3 단계, 이미지 1/1
    • Remove the battery.
  4. How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: 4 단계, 이미지 1/3 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: 4 단계, 이미지 2/3 How to Dry Wet Canon PowerShot SD850 IS Camera Components, Housing: 4 단계, 이미지 3/3
    • To avoid severe electric shock do not remove or tamper with internal camera flash components. An electrical capacitor is attached to the flash that can discharge if contact is made.
    • Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
    • Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
    • Remove the front face by gently peeling the housing away from the camera.
  5. How to Dry Wet Canon PowerShot SD850 IS Camera Components: 5 단계, 이미지 1/3 How to Dry Wet Canon PowerShot SD850 IS Camera Components: 5 단계, 이미지 2/3 How to Dry Wet Canon PowerShot SD850 IS Camera Components: 5 단계, 이미지 3/3
    • Remove the back face by using a spudger to lift the tab highlighted in yellow
    • Pivot the back face clockwise as seen in the second photo.
  6. How to Dry Wet Canon PowerShot SD850 IS Camera Components: 6 단계, 이미지 1/2 How to Dry Wet Canon PowerShot SD850 IS Camera Components: 6 단계, 이미지 2/2
    • Remove the A/V port cover [no tools are necessary]
  7. How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: 7 단계, 이미지 1/2 How to Dry Wet Canon PowerShot SD850 IS Camera Components, How to Dry Wet Canon PowerShot SD850 IS Camera Components: 7 단계, 이미지 2/2
    • Use compressed air to dry off camera's internal components.
    • Use caution when performing this step. Compressed air could possibly damage components if sprayed directly at connections or other sensitive areas.
결론
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 9
전체 시간: 2,476
