주요 콘텐츠로 건너뛰기
How to Dry and Preserve a Bouquet
필요한 것
  1. How to Dry and Preserve a Bouquet, Prepare a bouquet: 1 단계, 이미지 1개 중 1개
    • First and foremost, prepare a bouquet, which may come from your friends or parents as a present, or brought home from a grocery shopping trip. It is advisable to choose colorful flowers for better results.
  2. How to Dry and Preserve a Bouquet, Use scissors to cut each stem: 2 단계, 이미지 1개 중 1개
    • Once you have the flowers, use scissors or cutters to cut each stem to expose a slanted surface, making each stem look like the sharp end of a straw.
  3. How to Dry and Preserve a Bouquet, Add supplements in the water: 3 단계, 이미지 1개 중 1개
    • The purpose of the second step is made clear in the third step: the slanted surface maximizes the surface contact with water, making the flowers more durable and vibrant while you enjoy them in a water-filled vase.
    • Optionally, you may add supplements in the water, like flower food, to enhance the blossoms.
  4. How to Dry and Preserve a Bouquet, Wait several days and enjoy: 4 단계, 이미지 1개 중 1개
    • After a few days on display, the flowers would reach their peak of liveness, which is also the best time to begin drying.
  5. How to Dry and Preserve a Bouquet, Use scissors to cut the tip of the petals: 5 단계, 이미지 1개 중 1개
    • As the fifth step, use scissors to carefully cut the tip of the petals to create leveled planes for each blossom. If each petal were kept at a different length, the drying process would happen unevenly across different parts of the blossom.
  6. How to Dry and Preserve a Bouquet, Dry up the bouquet: 6 단계, 이미지 1개 중 1개
    • In the sixth and most crucial step, use ropes or strings to tie the stems separately to a drying rack or cloth hangers upside-down. Place the rack or hangers at a ventilated place for it to naturally dry up in one or two weeks.
  7. How to Dry and Preserve a Bouquet, Put in a vase: 7 단계, 이미지 1개 중 1개
    • At the ending of the drying process, the criteria for properly dried flowers are that the stems are hard like a wood branch and the petals are darker in color.
    • Finally, bundle all the flowers together to put in an empty vase that you like to enjoy for a long while.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lisha Li
회원 가입일: 09/17/21
445 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 20
전체 시간: 402
