주요 콘텐츠로 건너뛰기
How to Dye a Used Shirt
필요한 것
  1. How to Dye a Used Shirt, How to Dye a Used Shirt: 1 단계, 이미지 1/1
    • The dye used for this guide is Rit DyeMore.
    • Buy the product and make sure to read the instructions on the bottle.
    • Weigh your shirt & follow instructions on the bottle according to weight to determine how much dye is needed.
    • Pre-wash your clothing item and prepare your materials and work area.
  2. How to Dye a Used Shirt: 2 단계, 이미지 1/1
    • Add enough water in a stainless steel pot to let the clothing item move freely.
  3. How to Dye a Used Shirt: 3 단계, 이미지 1/1
    • Add 1 tsp of dish detergent to the pot.
  4. How to Dye a Used Shirt: 4 단계, 이미지 1/1
    • Cover the pot and let the water reach close to boiling temperature ~200 degrees Fahrenheit.
  5. How to Dye a Used Shirt: 5 단계, 이미지 1/1
    • Add the desired amount of dye that was measured via the bottle to the water and turn the stove top temperature to simmer.
  6. How to Dye a Used Shirt: 6 단계, 이미지 1/2 How to Dye a Used Shirt: 6 단계, 이미지 2/2
    • Place wet clothing item in the solution.
    • Stir slowly for 10 minutes.
  7. How to Dye a Used Shirt: 7 단계, 이미지 1/2 How to Dye a Used Shirt: 7 단계, 이미지 2/2
    • After the desired color is achieved, remove the item from the solution.
    • Rinse the clothing item with warm water.
    • Gradually use cooler water until the water runs clear.
    • Wash the clothing item in warm water.
    • Dry and enjoy your new clothing item!
결론
Enjoy your new wardrobe!
다른 2명이 해당 안내서를 완성하였습니다.
Samantha Scully
회원 가입일: 03/23/21
193 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G14, O'Connell Spring 2021 UMass Dartmouth, Team S1-G14, O'Connell Spring 2021 회원
UMASSD-O'CONNELL-S21S1G14
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 25
전체 시간: 474
