소개
If you've stumbled upon this guide, odds are that your Nintendo Switch Pro controller is acting a bit strange. Maybe it's causing your character to move in a completely different direction from what you wanted. Maybe your character is moving on its own without you even touching the controller! If so, you are experiencing something video game enthusiasts refer to as "joystick drift," which is usually a result of dirt and debris that gets trapped within the joystick.
It's difficult to enjoy a video game when your controller is working against you. You may be tempted to throw away the controller and buy a new one, but a Nintendo Switch Pro Controller has an MSRP of nearly $70.00!
Fortunately, there is a relatively easy fix for joystick drift. The solution involves taking apart the controller to clean the inside of the joysticks. This guide will show you how to do this safely and quickly.
필요한 것
Remove the two black screws at the bottom ends of the controller using a Phillips #00 screwdriver.
Pull the hand grips off the bottom edges of the controller.
Remove the four silver screws from the back of the controller using a Phillips #00 screwdriver.
Hold the controller as depicted in the third picture with your thumbs placed on the top of the controller. Use your thumbs to pry apart the backplate from the rest of the controller.
Place a finger in the gap to the left of the battery.
Use the small tab on the side of the battery to remove the battery from the controller.
Remove the five black screws from the back of the controller using a Phillips #00 screwdriver.
Place a finger between the faceplate and the rest of the controller and pull each half of the controller apart to separate them.
Use one hand to grip the back of the controller piece with the joysticks. With the other hand, grip the rubber cap of the joystick and carefully pull it off of the joystick.
Spray the can of compressed air inside and around the joysticks to remove any debris.
Place the rubber caps back on the joysticks by applying a bit of pressure.
Align both halves of the controller and push them together. They should reattach easily.
Screw in the five black screws on the back of the controller using a Phillips #00 screwdriver.
Place the battery into the socket by aligning the connectors on the battery with the connectors on the right of the battery socket.
Align the backplate of the controller as shown in the picture and snap it on.
Screw in the four silver screws in the back of the controller using a Phillips #00 screwdriver.
Reattach the handgrips by sliding them onto the ends of the controller.
Screw in the two black screws on the bottom of the handgrips using a Phillips #00 screwdriver.
After following these steps, your controller will be much cleaner now than it was before. Your controller should now be drift-free and function as well as any other $70.00 controller!
If you are still experiencing drift, then there is a physical defect with the joystick. In this case, you can opt to replace the joystick itself. You can find replacement parts online, but you will probably need to learn how to solder in order to install the replacement joystick.
다른 43명이 해당 안내서를 완성하였습니다.
댓글 10개
Excellent. Really clear guide. Thank you so much
Worked like a charm! Thank you!
My controller has been having this issue, I've been opening it up and dusting the stick, but that only temporarily fixes this issue. I am considering replacing the stick module, although I am a bit worried that something else is causing drift. Its possible that the shell or upper stick part has worn out or has some sort of opening which is allowing dust and other particles to get into the stick. Any advice?
This is the first thing I have used my iFixit kit to try and fix and it worked perfectly. Thanks for a very helpful and clear to follow guide.
