주요 콘텐츠로 건너뛰기
How to Enlarge a Skirt Waistband
필요한 것
  1. How to Enlarge a Skirt Waistband, How to Enlarge a Skirt Waistband: 1 단계, 이미지 1개 중 1개
    • Measure the waist band with a ruler or measuring tape.
    • Measure your waist.
    • Subtract the two measurements to determine how many inches you want to add on.
  2. How to Enlarge a Skirt Waistband: 2 단계, 이미지 3개 중 1개 How to Enlarge a Skirt Waistband: 2 단계, 이미지 3개 중 2개 How to Enlarge a Skirt Waistband: 2 단계, 이미지 3개 중 3개
    • Measure roughly 2 inches below the waistband.
    • Mark a vertical line with a tailor's chalk, a white pencil, or pins.
    • Cut down to the end of the line.
  3. How to Enlarge a Skirt Waistband: 3 단계, 이미지 3개 중 1개 How to Enlarge a Skirt Waistband: 3 단계, 이미지 3개 중 2개 How to Enlarge a Skirt Waistband: 3 단계, 이미지 3개 중 3개
    • Measure and mark the elastic to twice the length you want to add on.
    • Cut the elastic strip.
    • Then, cut that same strip at the halfway mark.
  4. How to Enlarge a Skirt Waistband: 4 단계, 이미지 3개 중 1개 How to Enlarge a Skirt Waistband: 4 단계, 이미지 3개 중 2개 How to Enlarge a Skirt Waistband: 4 단계, 이미지 3개 중 3개
    • Overlap your elastic strips from step 3.
    • Depending on how many inches you are adding on, you may need to cut several strips.
    • Sew the strips together
    • Be cautious of where you place your fingers when dealing with sharp objects.
  5. How to Enlarge a Skirt Waistband: 5 단계, 이미지 2개 중 1개 How to Enlarge a Skirt Waistband: 5 단계, 이미지 2개 중 2개
    • Fold the elastic in half.
    • Cut at about a 60 degree angle (creating a triangle).
  6. How to Enlarge a Skirt Waistband: 6 단계, 이미지 1개 중 1개
    • Turn the skirt inside out.
    • Sew the elastic triangle into the opening you cut in Step 2.
    • Try your new skirt on for size.
결승점
작성자
3다른 기여자 명과 함께
Nisha Sahota
회원 가입일: 11/05/24
133 평판
안내서 1개를 작성함
UC Davis, Team 4-7, Vidal-Chiesa Fall 2024 UC Davis, Team 4-7, Vidal-Chiesa Fall 2024 회원
UCD-VIDAL-CHIESA-F24S4G7
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 24
전체 시간: 221
