주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you forgot your Password, PIN, Pattern Screen Lock and you can't enter the phone menu with your Google account, registered on this device, the only way to bypass the security is Factory reset.
WARNING!
Factory Reset will permanently delete ALL of your data!
동영상 개요
  1. Switch off the phone. Press and hold: Volume Up, Volume down and Power buttons  together. When you see  the Ascend logo release only the  Power button.
    • Switch off the phone.
    • Press and hold: Volume Up, Volume down and Power buttons together.
    • When you see the Ascend logo release only the Power button.
    • This is Android System Recovery menu.
    • Use Volume Up/Down buttons for navigation and the Power button for OK and select one after the other: ......"wipe data/factory reset"......"Yes -- erase all data"......"reboot system now".
    • Did you do it successfully?
결론
다른 7명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
176,887 평판
안내서 317개 작성하였습니다
Master Techs Master Techs 회원
Community
295 회원들
안내서 968개 작성하였습니다
no please help
vmc - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 67
전체 시간: 22,254
