이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you forgot your Password, PIN, Pattern Screen Lock and you can't enter the phone menu with your Google account, registered on this device, the only way to bypass the security is Factory reset.
WARNING!
Factory Reset will permanently delete ALL of your data!
동영상 개요
Switch off the phone.
Press and hold: Volume Up, Volume down and Power buttons together.
When you see the Ascend logo release only the Power button.
This is Android System Recovery menu.
Use Volume Up/Down buttons for navigation and the Power button for OK and select one after the other: ......"wipe data/factory reset"......"Yes -- erase all data"......"reboot system now".
Did you do it successfully?
다른 7명이 해당 안내서를 완성하였습니다.
