주요 콘텐츠로 건너뛰기
How to Factory Reset an iPhone
  1. How to Factory Reset an iPhone, Navigate to the Settings Menu.: 1 단계, 이미지 3개 중 1개 How to Factory Reset an iPhone, Navigate to the Settings Menu.: 1 단계, 이미지 3개 중 2개 How to Factory Reset an iPhone, Navigate to the Settings Menu.: 1 단계, 이미지 3개 중 3개
    • Select the Settings App.
    • If you are unsure where your Settings App is, swipe all the way to the left and use the Search function to pull it up for you.
  2. How to Factory Reset an iPhone, Find Reset in Settings: 2 단계, 이미지 2개 중 1개 How to Factory Reset an iPhone, Find Reset in Settings: 2 단계, 이미지 2개 중 2개
    • Select General. It will likely be along the bottom edge of the first screen.
    • Scroll to the bottom of the following menu. Tap the Reset option. Depending on the version of iOS your phone is running it may alternatively read Transfer or Reset iPhone.
  3. How to Factory Reset an iPhone, Reset the iPhone: 3 단계, 이미지 3개 중 1개 How to Factory Reset an iPhone, Reset the iPhone: 3 단계, 이미지 3개 중 2개 How to Factory Reset an iPhone, Reset the iPhone: 3 단계, 이미지 3개 중 3개
    • Select the Erase All Content and Settings option.
    • The iPhone will confirm what information will be removed during this process. Click Continue at the bottom of the screen.
    • It will confirm one final time that you want to Erase it. It may ask for your Apple ID password to authenticate.
  4. How to Factory Reset an iPhone, Wait: 4 단계, 이미지 1개 중 1개
    • The phone will restart to an Apple logo. A progress bar will appear and fill as the the phone removes data and reinstalls the Operating System.
    • It may restart a few times during the process, or appear to be off for longer than usual between restarts.
    • After patiently waiting, the device will restart to the Setup Assistant allowing you to start configuration from scratch or someone else to do the same.
결론
The iPhone Setup Assistant will walk you through reactivating and configuring your device. If this reset was done to rule out a software problem, restore your data later. Be sure your issue is resolved without all the additional apps, data and settings changes.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alisha C
회원 가입일: 12/04/20
41,460 평판
안내서 9개를 작성함
LGBTQ Technicians LGBTQ Technicians 회원
Community
48 회원들
안내서 77개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 36
지난 7일: 197
지난 30일: 649
전체 시간: 6,421
