소개
Use this guide to repair the power supply with a Phillips head screwdriver, a wrench, and pliers. These tools will help secure the screw holding the wire.
First, to remove the plastic bracket, turn toaster oven on its side.
  • First, to remove the plastic bracket, turn toaster oven on its side.
댓글 쓰기
Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
  • Use Phillips head screwdriver and wrench to remove screw and nut securing the plastic bracket.
댓글 쓰기
Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
  • Use Phillips head screwdriver and pliers to remove screw and nut securing transformer.
댓글 쓰기
If the wire gets pulled out of the transformer, reinsert it.
  • If the wire gets pulled out of the transformer, reinsert it.
  • Use a small flathead screwdriver to secure the screw that holds the wire in place.
댓글 쓰기
결론
Tony Wang
회원 가입일: 2012년 10월 05일
64 평판
안내서 5개 작성하였습니다
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012 회원
CPSU-REGAN-F12S6G35
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 668
