주요 콘텐츠로 건너뛰기
How to Fix Cracked Door Jamb
필요한 것
  1. How to Fix Cracked Door Jamb, How to Fix Cracked Door Jamb: 1 단계, 이미지 1/1
    • Cracked door jamb/frame caused by excessive force on door.
  2. How to Fix Cracked Door Jamb: 2 단계, 이미지 1/1
    • Apply wood filler into the cracks of the door frame.
  3. How to Fix Cracked Door Jamb: 3 단계, 이미지 1/2 How to Fix Cracked Door Jamb: 3 단계, 이미지 2/2
    • Attach the clamp onto the cracked door frame.
    • Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
  4. How to Fix Cracked Door Jamb: 4 단계, 이미지 1/2 How to Fix Cracked Door Jamb: 4 단계, 이미지 2/2
    • Drill a pilot hole into the door frame.
    • Screw a 4-inch screw into the frame through the pilot hole.
  5. How to Fix Cracked Door Jamb: 5 단계, 이미지 1/1
    • Wait for the wood filler to dry.
    • Once dried, scrape off the excess filler with a scraper.
  6. How to Fix Cracked Door Jamb: 6 단계, 이미지 1/1
    • Sand the filled up cracks to get a smooth surface.
  7. How to Fix Cracked Door Jamb: 7 단계, 이미지 1/1
    • Paint and do not touch until dry.
  8. How to Fix Cracked Door Jamb: 8 단계, 이미지 1/2 How to Fix Cracked Door Jamb: 8 단계, 이미지 2/2
    • Repaired door frame/ door jamb.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Anisha Karaumbiah
회원 가입일: 02/17/18
256 평판
안내서 1개 작성함
UC Davis, Team S1-G1, Andersen Winter 2018 UC Davis, Team S1-G1, Andersen Winter 2018 회원
UCD-ANDERSEN-W18S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 103
30일 전: 459
전체 시간: 42,527
