주요 콘텐츠로 건너뛰기
How to Fast Fix a Crack on Granite Countertop
필요한 것
  1. How to Fast Fix a Crack on Granite Countertop, How to Fast Fix a Crack on Granite Countertop: 1 단계, 이미지 1개 중 1개
    • Ensure the surface to be cured is clean and dry.
    • When epoxies are mixed, the compound hardens rapidly. Before mixing, it is crucial to prepare the surface for repairs and to mix just enough to get the job done.
  2. How to Fast Fix a Crack on Granite Countertop: 2 단계, 이미지 3개 중 1개 How to Fast Fix a Crack on Granite Countertop: 2 단계, 이미지 3개 중 2개 How to Fast Fix a Crack on Granite Countertop: 2 단계, 이미지 3개 중 3개
    • Measure and mix an equal proportion of hardener and resin.
    • For a good curing effect, epoxy resin and hardener should be measured out in a 1:1 ratio.
    • Epoxy resins are safe to use if managed appropriately. Do not swallow; may be poisonous if swallowed.
  3. How to Fast Fix a Crack on Granite Countertop: 3 단계, 이미지 3개 중 1개 How to Fast Fix a Crack on Granite Countertop: 3 단계, 이미지 3개 중 2개 How to Fast Fix a Crack on Granite Countertop: 3 단계, 이미지 3개 중 3개
    • Add a small amount of tint to the hardener and resin.
    • Stir in until thoroughly mixed.
    • Tinting is optional when sealing or rejoining a piece of granite that has a clean split with no missing fragments.
    • Do not add too much tint!
  4. How to Fast Fix a Crack on Granite Countertop: 4 단계, 이미지 3개 중 1개 How to Fast Fix a Crack on Granite Countertop: 4 단계, 이미지 3개 중 2개 How to Fast Fix a Crack on Granite Countertop: 4 단계, 이미지 3개 중 3개
    • Apply the mixture to the crack or damaged area.
  5. How to Fast Fix a Crack on Granite Countertop: 5 단계, 이미지 2개 중 1개 How to Fast Fix a Crack on Granite Countertop: 5 단계, 이미지 2개 중 2개
    • Tape the cured area with some painters tape.
    • It is optional to use the painters tape on a flat surface. The strip aids in molding the epoxy to precise curves.
    • Allow to dry for 30-45 minutes.
    • Before removing strip, lift and feel the epoxy, and ensure it is dry.
    • Once dried, slowly peel back the tape and shave off the dried excess with a putty knife.
  6. How to Fast Fix a Crack on Granite Countertop: 6 단계, 이미지 3개 중 1개 How to Fast Fix a Crack on Granite Countertop: 6 단계, 이미지 3개 중 2개 How to Fast Fix a Crack on Granite Countertop: 6 단계, 이미지 3개 중 3개
    • Use a putty knife or a razor to scrape off excess epoxy.
    • For a visibly flat finish, it's best to use a razor to scrape off the dry epoxy.
  7. How to Fast Fix a Crack on Granite Countertop: 7 단계, 이미지 2개 중 1개 How to Fast Fix a Crack on Granite Countertop: 7 단계, 이미지 2개 중 2개
    • Depending on the product used, The finished surface may look glossy.
    • Apply a granite sealer over the area.
결론
Enjoy your crack free countertop!
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Deborah Kalu
회원 가입일: 07/01/23
172 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 15
지난 30일: 70
전체 시간: 3,461
