주요 콘텐츠로 건너뛰기
How to Fast Fix a sharp edge on a garage door
필요한 것
  1. How to Fast Fix a sharp edge on a garage door, How to Fast Fix a sharp edge on a garage door: 1 단계, 이미지 1/2 How to Fast Fix a sharp edge on a garage door, How to Fast Fix a sharp edge on a garage door: 1 단계, 이미지 2/2
    • Disconnect the garage door from the power supply.
  2. How to Fast Fix a sharp edge on a garage door: 2 단계, 이미지 1/2 How to Fast Fix a sharp edge on a garage door: 2 단계, 이미지 2/2
    • Spray the cleaning solution on the sharp edge of the garage door railing and the metal file.
  3. How to Fast Fix a sharp edge on a garage door: 3 단계, 이미지 1/1
    • Remove the debris from the sharp edge of the garage door using a brush.
  4. How to Fast Fix a sharp edge on a garage door: 4 단계, 이미지 1/3 How to Fast Fix a sharp edge on a garage door: 4 단계, 이미지 2/3 How to Fast Fix a sharp edge on a garage door: 4 단계, 이미지 3/3
    • Use the metal file to bevel the sharp edge of the garage door by grinding against it in a curved motion.
  5. How to Fast Fix a sharp edge on a garage door: 5 단계, 이미지 1/1
    • Use the metal brush to clear the debris from the beveled edge.
  6. How to Fast Fix a sharp edge on a garage door: 6 단계, 이미지 1/2 How to Fast Fix a sharp edge on a garage door: 6 단계, 이미지 2/2
    • Clean the beveled edge using the rag and the cleaning solution.
결론
Assess the sharpness of the edge and bevel further if necessary.
Dylan Thompson
회원 가입일: 09/19/22
133 평판
안내서 1개 작성함
University of Memphis, Team 1-1, Cameron Fall 2022 University of Memphis, Team 1-1, Cameron Fall 2022 회원
UM-CAMERON-F22S1G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 180
