주요 콘텐츠로 건너뛰기
How to Fill a Gap with Latex Caulk
필요한 것
  1. How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 1 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 1 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk, How to Fill a Gap with Latex Caulk: 1 단계, 이미지 3개 중 3개
    • Clean all surfaces and remove any clutter.
  2. How to Fill a Gap with Latex Caulk: 2 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk: 2 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk: 2 단계, 이미지 3개 중 3개
    • Use the latex paint remover spray for the areas that have remaining material along with the gaps. These areas also need to be replaced with new material.
  3. How to Fill a Gap with Latex Caulk: 3 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk: 3 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk: 3 단계, 이미지 3개 중 3개
    • Use scissors to cut the head of the caulk tube at a 45 degree angle.
    • This will help to better fill the gaps.
  4. How to Fill a Gap with Latex Caulk: 4 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk: 4 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk: 4 단계, 이미지 3개 중 3개
    • Insert the seal punch into the tip of the latex tube to pierce a hole.
  5. How to Fill a Gap with Latex Caulk: 5 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk: 5 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk: 5 단계, 이미지 3개 중 3개
    • Pull back the handle of the caulk gun.
    • Place the caulk tube inside it.
    • Twist the metal bar until it is completely inside the caulk tube and the curved handle is on top.
  6. How to Fill a Gap with Latex Caulk: 6 단계, 이미지 3개 중 1개 How to Fill a Gap with Latex Caulk: 6 단계, 이미지 3개 중 2개 How to Fill a Gap with Latex Caulk: 6 단계, 이미지 3개 중 3개
    • Add the latex to the areas you see gaps.
    • After finishing each side, slide your finger along the caulk to push the material inside the gaps.
    • Use a wipe to immediately clean the excess from the filled areas.
  7. How to Fill a Gap with Latex Caulk: 7 단계, 이미지 1개 중 1개
    • Use latex remover spray to remove any material stuck to your hand.
결승점
작성자
1다른 기여자 명과 함께
Ehsan Alagheband
회원 가입일: 09/16/21
153 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 30
전체 시간: 849
