주요 콘텐츠로 건너뛰기
How to Fix A Broken Makeup Compact Without Alcohol
필요한 것
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: 1 단계, 이미지 1/1
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: 2 단계, 이미지 1/1
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: 3 단계, 이미지 1/1
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: 4 단계, 이미지 1/2 How to Fix A Broken Makeup Compact Without Alcohol: 4 단계, 이미지 2/2
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 1/3 How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 2/3 How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 3/3
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 1/3 How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 2/3 How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 3/3
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 1/3 How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 2/3 How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 3/3
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
결승점
Cura Mclemore
회원 가입일: 03/21/23
145 평판
안내서 1개 작성함
University of Memphis, Team 12-12, Peters Spring 2023 University of Memphis, Team 12-12, Peters Spring 2023 회원
UM-PETERS-S23S12G12
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 188
