주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix A Broken Makeup Compact Without Alcohol
필요한 것
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: 1 단계, 이미지 1개 중 1개
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: 2 단계, 이미지 1개 중 1개
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: 3 단계, 이미지 1개 중 1개
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: 4 단계, 이미지 2개 중 1개 How to Fix A Broken Makeup Compact Without Alcohol: 4 단계, 이미지 2개 중 2개
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 3개 중 1개 How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 3개 중 2개 How to Fix A Broken Makeup Compact Without Alcohol: 5 단계, 이미지 3개 중 3개
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 3개 중 1개 How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 3개 중 2개 How to Fix A Broken Makeup Compact Without Alcohol: 6 단계, 이미지 3개 중 3개
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 3개 중 1개 How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 3개 중 2개 How to Fix A Broken Makeup Compact Without Alcohol: 7 단계, 이미지 3개 중 3개
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
결승점
작성자
1다른 기여자 명과 함께
Cura Mclemore
회원 가입일: 03/21/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 44
전체 시간: 552
