주요 콘텐츠로 건너뛰기
How to Fix A Cracked Leather Jacket
필요한 것
  1. How to Fix A Cracked Leather Jacket, How to Fix A Cracked Leather Jacket: 1 단계, 이미지 3개 중 1개 How to Fix A Cracked Leather Jacket, How to Fix A Cracked Leather Jacket: 1 단계, 이미지 3개 중 2개 How to Fix A Cracked Leather Jacket, How to Fix A Cracked Leather Jacket: 1 단계, 이미지 3개 중 3개
    • Clean the area you’re repairing with a towel and rubbing alcohol.
    • Gently wipe the area that is damaged.
  2. How to Fix A Cracked Leather Jacket: 2 단계, 이미지 2개 중 1개 How to Fix A Cracked Leather Jacket: 2 단계, 이미지 2개 중 2개
    • Cut the sub-patch to fit the hole and tuck it beneath the leather’s surface.
    • Make sure the patch is lump-free and smooth underneath the leather.
  3. How to Fix A Cracked Leather Jacket: 3 단계, 이미지 3개 중 1개 How to Fix A Cracked Leather Jacket: 3 단계, 이미지 3개 중 2개 How to Fix A Cracked Leather Jacket: 3 단계, 이미지 3개 중 3개
    • Put glue on the applicator.
    • With the applicator, spread the glue over the patch and both sides of the tear.
  4. How to Fix A Cracked Leather Jacket: 4 단계, 이미지 2개 중 1개 How to Fix A Cracked Leather Jacket: 4 단계, 이미지 2개 중 2개
    • Wipe off any extra glue right away with a rag.
  5. How to Fix A Cracked Leather Jacket: 5 단계, 이미지 2개 중 1개 How to Fix A Cracked Leather Jacket: 5 단계, 이미지 2개 중 2개
    • Rejoin the seam and secure it in position.
  6. How to Fix A Cracked Leather Jacket: 6 단계, 이미지 3개 중 1개 How to Fix A Cracked Leather Jacket: 6 단계, 이미지 3개 중 2개 How to Fix A Cracked Leather Jacket: 6 단계, 이미지 3개 중 3개
    • Secure the seam with masking tape.
    • Wait for it to dry for approximately 2 hours.
  7. How to Fix A Cracked Leather Jacket: 7 단계, 이미지 3개 중 1개 How to Fix A Cracked Leather Jacket: 7 단계, 이미지 3개 중 2개 How to Fix A Cracked Leather Jacket: 7 단계, 이미지 3개 중 3개
    • Gently pull off the tape after the two hour waiting period.
결론
Repeat this process with any other cracks on a leather garment.
작성자
5다른 기여자 명과 함께
Ashley Castillo
회원 가입일: 02/01/23
145 평판
안내서 1개를 작성함
UC Davis, Team 2-6, Andersen Winter 2023 UC Davis, Team 2-6, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S2G6
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 66
지난 30일: 311
전체 시간: 5,858
