소개
Loose screws and detached hinges can cause cabinet doors to become crooked. To some, this may look like a job for a contractor, but thankfully re-aligning a cabinet is a quick and easy fix that will save you time and money!
In this guide, I will show you a simple way to fix your crooked cabinet. The pictures demonstrate a cabinet with a soft-closing multi-adjustable door hinge.
필요한 것
Open the cabinet door, and determine where it is misaligned.
Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
다른 한 분이 해당 안내서를 완성하였습니다.
