주요 콘텐츠로 건너뛰기
How to Fix A Crooked Cabinet Door
필요한 것
  1. How to Fix A Crooked Cabinet Door, How to Fix A Crooked Cabinet Door: 1 단계, 이미지 1개 중 1개
    • Open the cabinet door, and determine where it is misaligned.
  2. How to Fix A Crooked Cabinet Door: 2 단계, 이미지 1개 중 1개
    • Re-attach the hinge into place.
    • Soft-closing multi-adjustable hinges can snap back into their thickness plates which is the part attached to the inside of the cabinet.
    • Avoid placing your fingers near the thickness plate as its force can cause a painful pinch.
  3. How to Fix A Crooked Cabinet Door: 3 단계, 이미지 1개 중 1개
    • Hold the hinge firmly against the thickness plate and tighten the screw until the hinge is no longer loose.
    • There are different methods for aligning your cabinet door depending on the screw you tighten and the direction:
    • Side-to-Side Adjustment: To move the door away from the cabinet, screw clockwise. To move the door closer to the cabinet, screw in a counterclockwise motion.
    • Up-Down Adjustment: Screw in a clockwise motion to move the door up. A counterclockwise motion will move the door down.
  4. How to Fix A Crooked Cabinet Door: 4 단계, 이미지 1개 중 1개
    • The result of the tightened hinge will look as pictured.
  5. How to Fix A Crooked Cabinet Door: 5 단계, 이미지 1개 중 1개
    • Measure along the top and sides of the cabinet with a balance ruler or standard ruler.
    • The result should look as pictured.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Camrynne Paul
회원 가입일: 03/19/22
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 24
지난 30일: 90
전체 시간: 10,713
