주요 콘텐츠로 건너뛰기
How to Fix A Rusted Hitch
필요한 것
  1. How to Fix A Rusted Hitch, How to Fix A Rusted Hitch: 1 단계, 이미지 1/1
    • This is the before picture of the rusted hitch.
  2. How to Fix A Rusted Hitch: 2 단계, 이미지 1/1
    • Apply the wire brush on any part of the hitch in order to brush off any excess rust or rust flakes.
  3. How to Fix A Rusted Hitch: 3 단계, 이미지 1/2 How to Fix A Rusted Hitch: 3 단계, 이미지 2/2
    • Use the small paint brush to apply a coat of naval jelly over the rusted area.
    • Allow to sit for approximately ten minutes.
    • Remember to use caution/gloves when handling the naval jelly.
  4. How to Fix A Rusted Hitch: 4 단계, 이미지 1/1
    • Dip the paper towel in a bowl of lukewarm water to get the paper towel damp.
  5. How to Fix A Rusted Hitch: 5 단계, 이미지 1/1
    • Take the wet paper towel and wipe off the naval jelly on the hitch.
  6. How to Fix A Rusted Hitch: 6 단계, 이미지 1/1
    • Apply a protective layer of fluid film to the treated area.
    • Spray approximately 4-6 inches away from the hitch.
  7. How to Fix A Rusted Hitch: 7 단계, 이미지 1/1
    • Allow the fluid film to sit for about 5 minutes.
    • You should start to see bubbling in this process.
  8. How to Fix A Rusted Hitch: 8 단계, 이미지 1/1
    • This is the finished, rust-free, product.
결론
This procedure cannot be performed again immediately after the rust is taken off. Repeat these steps when rust develops over time.
다른 한 분이 해당 안내서를 완성하였습니다.
Kiley Strickland
회원 가입일: 01/20/19
184 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 회원
USFSM-STEWART-S19S1G1
18 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 60
전체 시간: 1,391
