주요 콘텐츠로 건너뛰기
How to Fix A Smart TV That’s Not Connecting To Wi-Fi
결론
다른 2명이 해당 안내서를 완성하였습니다.
Samuel Worku
회원 가입일: 08/25/22
229 평판
안내서 2개 작성하였습니다
CSU Los Angeles, Team 13-6, Briggs Fall 2022 CSU Los Angeles, Team 13-6, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S13G6
1 회원
안내서 3개 작성하였습니다
댓글 4개
very useful i liked it
David Kasamba - 답글
Mi tv smar no acepta rerminis y condiciones
Miiriian Estrada - 답글
Tienes que marcar la casilla antes de que tu prensa acepte. Pon una marca de verificación en el pequeño cuadrado.
AmZeeel -
Hey, It depends on your TV model or device. There are many reasons behind a TV not connecting to internet, these are a few solutions to that problem: First thing to check is you wifi router, check if your other devices are connected. Your TV must very close to your wifi router. Wi-Fi routers operating on the traditional 2.4 GHz band reach up to 150 feet (46 m) indoors and 300 feet (92 m) outdoors.
Next thing to check is date, time and region. You have to adjust date, time and your location. If none helps, connect an ethernet cable directly to your TV, a wired connection is more stable and reliable than wifi, Good luck!
AmZeeel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 106
30일 전: 469
전체 시간: 2,510
