주요 콘텐츠로 건너뛰기
How to Fix A Squeaky Elliptical
필요한 것
  1. How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 1 단계, 이미지 3개 중 1개 How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 1 단계, 이미지 3개 중 2개 How to Fix A Squeaky Elliptical, How to Fix A Squeaky Elliptical: 1 단계, 이미지 3개 중 3개
    • Test out your elliptical by swinging the cord side to side and listening for noise.
    • Is the squeaking coming from multiple locations or maybe just one screw? Most likely, it will be the coming from the connection between the bolt and the cord.
  2. How to Fix A Squeaky Elliptical: 2 단계, 이미지 1개 중 1개
    • Use a general multi-purpose cleaner and a dry cloth or paper towel to remove dust and gunk from your machine.
  3. How to Fix A Squeaky Elliptical: 3 단계, 이미지 1개 중 1개
    • Use compressed air to get rid of debris that is harder to reach, especially parts that cover the bolt and cords on your elliptical.
  4. How to Fix A Squeaky Elliptical: 4 단계, 이미지 2개 중 1개 How to Fix A Squeaky Elliptical: 4 단계, 이미지 2개 중 2개
    • Use WD-40 wherever two pieces connect to make sure there's no rubbing between parts. Make sure to get it deep in the corners and really saturate the metal.
    • You can also use it in places you think might get rustier over time or might collect moisture.
  5. How to Fix A Squeaky Elliptical: 5 단계, 이미지 1개 중 1개
    • Use a cotton swab to apply grease to the bolts.
  6. How to Fix A Squeaky Elliptical: 6 단계, 이미지 3개 중 1개 How to Fix A Squeaky Elliptical: 6 단계, 이미지 3개 중 2개 How to Fix A Squeaky Elliptical: 6 단계, 이미지 3개 중 3개
    • Test out your machine to make sure that it no longer squeaks by doing the same motions from Step 1. If your machine still makes noise, repeat Steps 3 through 5.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
calvez18
회원 가입일: 09/20/20
133 평판
안내서 1개를 작성함
York University, Team S2-G2, Melo-Thaiss Fall 2020 York University, Team S2-G2, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G2
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 77
전체 시간: 5,407
