이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Test out your elliptical by swinging the cord side to side and listening for noise.
Use a general multi-purpose cleaner and a dry cloth or paper towel to remove dust and gunk from your machine.
Use compressed air to get rid of debris that is harder to reach, especially parts that cover the bolt and cords on your elliptical.
Use WD-40 wherever two pieces connect to make sure there's no rubbing between parts. Make sure to get it deep in the corners and really saturate the metal.
Test out your machine to make sure that it no longer squeaks by doing the same motions from Step 1. If your machine still makes noise, repeat Steps 3 through 5.
다른 한 분이 해당 안내서를 완성하였습니다.
