주요 콘텐츠로 건너뛰기
How to Fix A Stripped Screw Hole
필요한 것
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: 1 단계, 이미지 1/1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: 2 단계, 이미지 1/2 How to Fix A Stripped Screw Hole: 2 단계, 이미지 2/2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: 3 단계, 이미지 1/2 How to Fix A Stripped Screw Hole: 3 단계, 이미지 2/2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: 4 단계, 이미지 1/1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: 5 단계, 이미지 1/1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: 6 단계, 이미지 1/2 How to Fix A Stripped Screw Hole: 6 단계, 이미지 2/2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
결론
Your screw should now hold secure.
Isaiah Valdez Mireles
회원 가입일: 08/22/22
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 3-24, Briggs Fall 2022 CSU Los Angeles, Team 3-24, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S3G24
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 55
전체 시간: 1,537
