주요 콘텐츠로 건너뛰기
How to Fix A Warped Frisbee Disc
필요한 것
  1. How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: 1 단계, 이미지 2개 중 1개 How to Fix A Warped Frisbee Disc, How to Fix A Warped Frisbee Disc: 1 단계, 이미지 2개 중 2개
    • Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
  2. How to Fix A Warped Frisbee Disc: 2 단계, 이미지 1개 중 1개
    • Take the bowl and fill halfway full with water. Microwave until water is boiling.
    • The bowl will be hot, so handle it with care.
  3. How to Fix A Warped Frisbee Disc: 3 단계, 이미지 1개 중 1개
    • Take the bowl with boiling water and place it on top of the frisbee and the towel.
  4. How to Fix A Warped Frisbee Disc: 4 단계, 이미지 1개 중 1개
    • Add a textbook as a weight to sit on top of the bowl.
    • Let everything sit for 1 hour
  5. How to Fix A Warped Frisbee Disc: 5 단계, 이미지 1개 중 1개
    • Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
    • If it is still warped repeat this process one more time.
결론
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bryce Petersen
회원 가입일: 04/09/15
164 평판
안내서 1개를 작성함
Cal Poly, Team 30-5, Green Spring 2015 Cal Poly, Team 30-5, Green Spring 2015 회원
CPSU-GREEN-S15S30G5
5 회원들
안내서 32개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 14
전체 시간: 10,115
