이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
For frisbee owners, a warped disc is a common problem due to prolonged sun exposure or moderate wear over time. For most discs, this warping can often be undone with some gentle manipulation. This fix involves a simple set up, and then letting the frisbee sit for approximately 1 hour.
필요한 것
Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
The time taken to fix the warping on your frisbee may vary based on how thick the plastic is.
다른 2명이 해당 안내서를 완성하였습니다.
