이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place the frisbee disc on a flat surface with the concave side facing up. Lay a towel down flat over the frisbee.
Take the bowl and fill halfway full with water. Microwave until water is boiling.
Take the bowl with boiling water and place it on top of the frisbee and the towel.
Add a textbook as a weight to sit on top of the bowl.
Let everything sit for 1 hour
Remove any weights, the bowl, and the towel. Check to see if the disc is still warped.
다른 2명이 해당 안내서를 완성하였습니다.
