주요 콘텐츠로 건너뛰기
How to Fix Analog Drift for the SCUF IMPACT
필요한 것
  1. How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: 1 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: 1 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT, How to Fix Analog Drift for the SCUF IMPACT: 1 단계, 이미지 3/3
    • Unlock the L3 or R3 ring by turning it counter clockwise.
    • Remove the L3 or R3 ring.
  2. How to Fix Analog Drift for the SCUF IMPACT: 2 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT: 2 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT: 2 단계, 이미지 3/3
    • Pull the analog gently in order to get it out.
  3. How to Fix Analog Drift for the SCUF IMPACT: 3 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT: 3 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT: 3 단계, 이미지 3/3
    • Use a tweezer tip to gently open the green box.
  4. How to Fix Analog Drift for the SCUF IMPACT: 4 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT: 4 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT: 4 단계, 이미지 3/3
    • Locate the sensor in the green box and take it out slowly.
  5. How to Fix Analog Drift for the SCUF IMPACT: 5 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT: 5 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT: 5 단계, 이미지 3/3
    • Dip the q-tip in rubbing alcohol to clean the sensor and inside the green box for any dust or dirt.
  6. How to Fix Analog Drift for the SCUF IMPACT: 6 단계, 이미지 1/3 How to Fix Analog Drift for the SCUF IMPACT: 6 단계, 이미지 2/3 How to Fix Analog Drift for the SCUF IMPACT: 6 단계, 이미지 3/3
    • Place the sensor back in the box. To reassemble your controller, follow the instructions 1-4 in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Amirparsa Monshi
회원 가입일: 09/27/21
157 평판
안내서 1개 작성함
York University, Team 1-15, O'Regan Fall 2021 York University, Team 1-15, O'Regan Fall 2021 회원
YORK-O'REGAN-F21S1G15
1 회원
안내서 3개 작성하였습니다
댓글 3개
HIGHLY RECOMMENDED! You saved my life. I have a lot of stick drift in my left analog that ruined my gaming experience through running movement in most of my games (Warzone, Apex, Fortnite) and this tutorial fix it ! I had some black crap on the sensor when I take them off and rubbing it with alcohol and a fine needle solve it. Thanks so much!!!
Alexandre Beauregard - 답글
My green caps will not pop back on!!!
luke-froeba - 답글
Did this and got the boxes back on but now my stick is broke. Just get stuck whenever moving it up or down and cannot be pressed down any more..
Treyben Funderburg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 35
30일 전: 159
전체 시간: 22,591
